rules for window locks
30 Oct 2008
West Midlands
As part of the new regs (yes prezza again) certain rented houses now have to have locks on the ground floor that can be opened without a key. e.g. a thumbturn deadlock for the front door (i.e. key from outside only) and something similar for the windows.
Anyone know if this is still the case as our house used to be a rental property and at some point someone decided to install a window (note 1 window) with a keyloss lock (ie push button). Thing is, most insurers are now starting to insist on key operated locks and I was just wondering whether to get the lock changed.
Sadie.
why not ask your insurance company, they insure your house, we don't
Sadie.
It should be on your insurance policies what is needed. I have changed all my window handles to lockable type otherwise the insurance is invalid!
to meet current building regs and means of escape NOT all windows should have a lock on them,,, insurance companies do not insists all windows should be lockable,,, the button is normally green but not always the case,,, you should have 2 means of escape from anyroom in case of fire,,, ie the door and at least one window,,, buut the window must have a clear opening of 450mm,,, so you would not expect to see a non locking window on your top sash for example..
Probably because not all insurers will give proper advice, and statutory requirements will override any contractual policy requirements every time
to meet current building regs ... you should have 2 means of escape from anyroom in case of fire,,,
Have you got a reference for this regulation so I can read it?
Part B 2002 of the building regs or BS 5588-1:1990 or later amendments
It's not any room though, but ones as defined in those documents - habitable rooms
woody is right its not any room but i think its one defined as habitable ie bedrooms lounge living etc,,, wet rooms may not apply but i bow to the superior knowledge of woody on this one,,,,, tho i think youve got the jist,,,
