rodding query
2 Nov 2006
Lincolnshire
I'm just laying some new drains,and I have notified building control,there are two chambers,the 250mm Osma kind,and I was wondering about the practicality of rodding such a small chamber-nothing was said by the b.c. officer-is there meant to be a seperate rodding eye connected to one of the side branches on the chamber-I have a feeling I've seen it done like that.Bit out of my comfort zone!
the larger the chamber the deeper they can go - simple.
small diameter chambers (300mm) are for shallow access only.
i would suggest a maximum of 450-500mm depth for small chambers.
450mm wide chambers - 500-1000mm depth.
The idea is that most blockages will occur at a junction or bend.
If there is a 'normal' manhole in the neighbours garden or nearby, then you don't really need a big on in your garden.
The other consideration is how many times have you actually had to deal with a blockage in your drains?
Are you sure that 1/2 brick was not there before you started? :rolleyes:
