Can anyone please advise me on the following?
A few days ago, I noticed that the ball valve in the cold tank in the roof had started making a loud rushing noise when refilling the tank. It turned out that water was spraying out of the top of it and hitting the plastic lid of the tank - hence the new noise.
Perhaps the cold weather has caused the plastic to become brittle and break? Has anyone else experienced this before?
I assume the only solution is to replace the ball valve - unless anyone has any other suggestions or advice please?
TIA
V
PS In case it's relevant, ball valve started making loud vibrating noises several months ago but I fixed this (thanks to seeing posts for other people here) by fixing the nearby pipes more securely.
TIA
V
