DIYnot
Local | Network
   DIYnot > Forums
Local | Network
One Cold Radiator
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Exarch1978
from United Kingdom
PostPosted: Wed Nov 10, 2004 11:29 am Reply with quote
Have just moved into a house to find that one of the radiators will not heat up at all. Have tried bleading the radiator, both trv and valve on other side are fully open, also tried turning heating on and turning all other radiators off. Still no heat to the one, its an upstairs radiator if that helps. Also the pipes leading to the trv are also cold. Any ideas? icon_confused.gif
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Wed Nov 10, 2004 5:24 pm Reply with quote
take the rad off
put a bucket under the valve and turn it on slowly (water should be hot)
repeat for ohher valve
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 2 times
PostPosted: Wed Nov 10, 2004 6:49 pm Reply with quote
TRV might be stuck.
take off the head and check the pin moves up and down. If stuck try tapping it.
Back to top
The following user says thank you to brumylad for this useful post:
desboy (10 Oct 2009)
 Alert Moderators
Exarch1978
from United Kingdom
PostPosted: Fri Nov 12, 2004 10:10 am Reply with quote
Sorted yep the pin definitely was stuck, another job fixed with the subtlety of a claw hammer icon_wink.gif, cheers both.
Back to top
 Alert Moderators
shavvy
from United Kingdom
PostPosted: Fri Nov 12, 2004 8:41 pm Reply with quote
I`m sure 90% of the problems on these forums could be fixed if people just used a big enough hammer icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
garalper
PostPosted: Sun Dec 12, 2004 3:52 pm Reply with quote
I didn't understand the following posted comment. Can someone please explain? Thanks much:
"TRV might be stuck. take off the head and check the pin moves up and down. If stuck try tapping it."
What specifically are: "TRV"? the "head" and the "Pin"?
Thank you.
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Sun Dec 12, 2004 3:59 pm Reply with quote
thermostatic radiator valve
head is the bit that opens closes the valve depending on the air temp
the pin is the bit that joins the above two together
Back to top
 Alert Moderators
garalper
PostPosted: Sun Dec 12, 2004 4:03 pm Reply with quote
WOW. That was fast!! Thanks for the quick reply to my question!!!!!!!!
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Sun Dec 12, 2004 4:08 pm Reply with quote
Back to top
 Alert Moderators
markie76
from United Kingdom
PostPosted: Mon Feb 21, 2005 7:37 pm Reply with quote
Hi Guys,
Thats right I've got one cold radiator, well my girlfriend has in one of her rooms.
Its in the basement the supply and return pipe come down from the ceiling and one of the pipes is hot and gradually cooler all the way to the inlet valve where it is a little bit warm. The inlet & outlet valves seem to open and close freely when tried but the radiator stays cold. Have done the bleed but didn't have a hammer or spanner handy so didn't do anything else.
Any help much appreciated - would prefer a non radiator removal or loud banging solution as the landlady is a bit on the nosey side. The radiator has plain valves which are probably from the 70's. icon_smile.gif
Regards,
Mark.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 79 times
PostPosted: Mon Feb 21, 2005 7:45 pm Reply with quote
[quote="markie7 one of the pipes is hot and gradually cooler all the way to the inlet valve where it is a little bit warm.[/quote]
Back to top
 Alert Moderators
rob_zombie
from United Kingdom
PostPosted: Sat Jan 05, 2008 9:03 pm Reply with quote
brumylad wrote:
TRV might be stuck.
taking this off and hitting the small brass pin helped me gain 2 radiators back without an expensive call out charge!!!! THANKS
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 5 times
PostPosted: Sat Jan 05, 2008 9:12 pm Reply with quote
can u get to all the other rads that r working to turn them off to see if that one will circulate at all when its the only thing on.
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 554 times
PostPosted: Sat Jan 05, 2008 9:18 pm Reply with quote
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 5 times
PostPosted: Sat Jan 05, 2008 9:23 pm Reply with quote
probably beat BG to the job though.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Cold New Radiator 6 740 Wed Oct 18, 2006 11:17 am
getting a TRV off to fix a cold radiator 4 240 Fri Oct 29, 2010 3:23 pm
Cold radiator (microbore maxitwin system) 2 2500 Sun Sep 23, 2007 2:30 pm
One cold radiator! 4 6520 Mon Oct 23, 2006 3:24 pm
Cold Radiator 4 140 Fri Oct 29, 2010 5:19 pm
DIYnot
