Problem started yesterday when CH suddenly went off. I have a C&M Britony 80. The hot water works fine with the burner firing up when hot water tap is on. However when hot tap is off it should go back into CH mode according to instructions but it does not. The burner is lighting for about 5 seconds then goes out, it then waits for 30-60seconds lights again, burns for around 5 seconds then goes out. Just keeps doing that....
Looking at the diagram of the system i suspect the 3 way valve (diverter valve) as the pipe is hot going into it, the heat exchanger (for hot water) is hot and the pump and pipe from that is hot. The outgoing pipe (to the radiators) from the diverter valve stays cold. The pump seems to be runing.
I dont know alot about boilers, but im technically minded
Could it be this or am i barking up the wrong tree????
Has anyone heard of this before and is there anything else i can check?
