DIYnot
Local | Network
   DIYnot > Forums
Local | Network
mixer shower temperature problem - going hot/cold
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
briwall1
from United Kingdom
PostPosted: Mon Jan 05, 2009 6:04 pm Reply with quote
I have a Potterton Performa 28 combi boiler and a gainsborough mixer shower.
The problem I have is the water temperature changes from hot to cold then back to hot.
I had the same problem with a gainsborough thermostatic shower and changed it because I was told the problem was with the shower not the boiler.
We have a service contract with British Gas and it was one of their plumbers who told me to do this after he had checked the boiler.
The boiler is apparently running as it should so no problem there but how do I get over the temperature problem - do I need to fit a pressure reducing valve on the cold water supply to the shower?
Any help would be greatly appreciated.
Brian
Back to top
 Alert Moderators
Dusty4018
from United Kingdom
PostPosted: Mon Jan 05, 2009 6:13 pm Reply with quote
Does the problem occur when there are other demands on this cold supply IE toilet re filling, kitchen tap turned on, washing machine on etc ?.
Do you know the hardness of the water in your area.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2180 times
PostPosted: Mon Jan 05, 2009 6:22 pm Reply with quote
when you run bathtap, does it stay at an even temperature?
Back to top
 Alert Moderators
briwall1
from United Kingdom
PostPosted: Mon Jan 05, 2009 7:21 pm Reply with quote
There is no difference if another tap is run or the toilet is flushed.
The water is quite hard here, does that make a difference?
Thanks for the replies
Brian
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2180 times
PostPosted: Mon Jan 05, 2009 7:35 pm Reply with quote
Actually I meant: all taps closed apart from only hot bath tap; when you hold your hand in the flow, does it stay even or does it go up and down too?
Back to top
 Alert Moderators
briwall1
from United Kingdom
PostPosted: Mon Jan 05, 2009 7:47 pm Reply with quote
Just tried it with only the bath hot tap running and the shower stays cold, it doesnt fluctuate.
Brian
Back to top
 Alert Moderators
Dusty4018
from United Kingdom
PostPosted: Mon Jan 05, 2009 10:35 pm Reply with quote
Brian,
thermostatic shower units are normally made using two different materials, one revolves inside the other. As limescale damage increases with water temp it is possible that some of the working parts (on the hot side) are becoming scaled up & preventing smooth movement. This will effect the operation. How old is the unit. ?
Back to top
 Alert Moderators
briwall1
from United Kingdom
PostPosted: Tue Jan 06, 2009 8:44 am Reply with quote
I dont have a thermostatic shower, I changed it on the weekend after the gas board plumber told me it would be faulty.
I changed it for a normal mixer shower thinking if there was no thermostat the boiler would control th ewater temperature.
Incidentally I have tried it this morning with the cold tap running in the basin to see if that would lower the cold water pressure but it didt make any difference as the shower still went hot and cold.
Brian
Back to top
 Alert Moderators
diy
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 06, 2009 9:22 am Reply with quote
when you run just the hot tap, does the temp stay even.
Back to top
 Alert Moderators
briwall1
from United Kingdom
PostPosted: Tue Jan 06, 2009 11:25 am Reply with quote
I have tried running the bath hot tap when the shower is running and the shower stays cold.
Back to top
 Alert Moderators
Rico99
from United Kingdom
Thanked: 30 times
PostPosted: Tue Jan 06, 2009 11:38 am Reply with quote
briwall1,
You not quite understanding what they are asking.
Turn the shower OFF, run JST the BAT hot tap. Does the water from the BATH HOT fluctuate in temp.
Rico
Back to top
 Alert Moderators
briwall1
from United Kingdom
PostPosted: Tue Jan 06, 2009 1:19 pm Reply with quote
Oh, sorry!
no the bath temperature doesnt fluctuate, it stays a constant temperature.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Thermosatic Mixer Shower - Temperature hot & cold 2 680 Sun Aug 02, 2009 11:01 pm
thermostatic mixer shower temperature problem 5 1741 Fri Jun 22, 2007 7:20 pm
Mixer shower water temperature 2 500 Wed Jun 04, 2008 11:08 am
Unable to control temperature on mixer shower 2 380 Mon May 17, 2010 8:55 am
Baxi Bolier - Hot and Cold DHW Temperature Cycling Problem 19 2300 Mon Jul 23, 2007 8:31 pm
DIYnot
