DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Change UK plug to French
This topic originated from the How to page called Wiring a plug
Click here to return to the page called Wiring a plug.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
busylady
from Switzerland
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 4:13 pm    Post Subject:
Reply with quote Thanks
Help! I'm a Yank living in Switzerland who bought a UK lamp and need to plug it in here. I've changed my US lamps with no problem, but don't know what to do with the ground wire I find in the UK plug when I change to the French one with no place for it. Can anyone help me? Thanks so much!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 5:12 pm    Post Subject:
'converting' US luminairesmay be unsafe, as they may not be designed to carry 230 volts.
But to convert UK luminaires ( as well as grounded american ones) what you need is a proper french or swiss plug. Does your place actually use french plugs? the swiss don't use french plugs, they use Swiss plugs.
French plug and socket:
Swiss plug and socket:
Are you sure you don't mean 'europlug' by french plug?
Which is an ungrounded plug designed to work in most EU sockets.
Sorry if i was being patronising by asking you, but most people don't know of the different earthed plugs around Europe, they just see europlugs. Certainly it's not uncommon to find french sockets and plugs in switzerland, but swiss plugs and sockets I would imagine are far more common.
What you need to do is buy the correct grounded (as us europeans say 'earthed') plug for your sockets.
If it is the french one, you'll notice there's a hole in the plug, and a pin in the socket, you want to connect the earth to the hole.
If your sockets are unearthed, you could really do with a rewire.
Some notes as regards polarity:
These three pin plugs are polarized, unlike europlugs. Now, if your american lights came with a polarized plug, you should use these and observe polarity. However, you should check that all parts of your american lights to make sure they are safe for 230v. Are the cable, lamp connector, switches, etc. all rated at european voltage or not?
If you're not sure, don't use it.
A small piece of lexical nazism:
A lamp refers to the bulb, tube, or whatever.
I assume what you are calling a lamp is actually a luminaire.
Back to top
 Alert Moderators
busylady
from Switzerland
Thanked: 0 times
PostPosted: Thu Nov 11, 2004 5:35 pm    Post Subject:
OK, what I have is a tall object that sits atop a table, holding a bulb (French ampule) with a lamp shade. I think I need to go out and buy a Swiss grounded plug. I just had a French one on hand, as they have been easy to use for my American lamps (tall objects as above), usable if I change plugs (or use a travel converter plug) and use an European bulb (French ampule). Thanks for the advice, though...
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 7:56 am    Post Subject:
So what is a gas lamp, lava lamp, blue lamp, lamp post, genie of the lamp, oil lamp,
http://www.magicmushroomlamps.com/
__________________
His vorpal blade went snicker-snack
Back to top
 Alert Moderators
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 11:18 pm    Post Subject:
Lamp referring to the actual part on the oil lamp that burns the oil, the rest being the luminaire.
The bulb is actually the lamp, because it is by definition all that is needed (ignoring safety, connectors, etc.)
Or that's what i've always been taught.
Back to top
 Alert Moderators
AdamW
from Vatican City State
Thanked: 0 times
PostPosted: Tue Nov 23, 2004 9:43 pm    Post Subject:
Always good to meet a fellow pedant icon_wink.gif I would agree, this is why people refer to "lamp-stands" too. It is a stand on which a lamp is placed. You would not refer to a hat-stand as a hat.
Zen, I hope that when you hear people refer to the St Stephen's Tower clock as "Big Ben", you slap them around the face and ears whilst shouting "Big Ben is a bell, you fooooooool!!!" icon_biggrin.gif
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Nov 23, 2004 9:54 pm    Post Subject:
it should also be noted that there are plenty of ungrounded sockets that will take earthed german and french plugs
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Nov 23, 2004 9:56 pm    Post Subject:
for more info on plugs and sockets you can take a look at
http://en.wikipedia.org/wiki/Domestic_AC_power_plugs_%26_sockets
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Change a socket to a switch 10 1100 Tue Jun 27, 2006 1:07 pm
European lamp plug conversion 3 1000 Sun Jan 27, 2008 10:51 pm
travel plug 11 1080 Fri Sep 05, 2008 1:01 pm
Wiring a foreign plug 3 560 Wed Jul 29, 2009 3:02 pm
UK TO SPANISH PLUG 3 1020 Wed Oct 24, 2007 1:33 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
