DIYnot
Local | Network
   DIYnot > Forums
Local | Network
suggestions for toilet pan / soil pipe connector
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
caffreys
from United Kingdom
PostPosted: Thu Jan 08, 2009 5:49 pm Reply with quote
what would people suggest i use for this ?
soil pipe is 100mm or so (4") - should i cut the bell off ?
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 983 times
PostPosted: Thu Jan 08, 2009 6:32 pm Reply with quote
A bit of a difference in angle there but an angled or even straight pan connector should do it. There is some height misalignment so you need to either raise the w/c a little or cut the boss back so it doesn’t distort but make sure you leave enough length for the pan connector to fully engage the inside of the pipe.
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 136 times
PostPosted: Thu Jan 08, 2009 8:13 pm Reply with quote
id suggest you make a couple inch raised platform for it , it would be the easier and safer option ,
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 110 times
PostPosted: Thu Jan 08, 2009 8:50 pm Reply with quote
Raised platform and a multikwik MKB114S
http://www.multikwik.com/product_detail.php?recordID=MKB114S
Back to top
 Alert Moderators
ctp
from United Kingdom
Thanked: 16 times
PostPosted: Thu Jan 08, 2009 11:12 pm Reply with quote
is it lead? if so chisel out the plaster/wall under the pipe and dress it into the right position and use a pan connector
Back to top
 Alert Moderators
caffreys
from United Kingdom
PostPosted: Fri Jan 09, 2009 2:59 pm Reply with quote
cheers for the suggestions, ill chisel out the plaster and see state of play,
i should be able to use a mutikwik extension and connector then
(MKS2 and a MKEA) - didnt even think about knocking the wall about icon_biggrin.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 945 times
PostPosted: Fri Jan 09, 2009 3:24 pm Reply with quote
If it's Cast Iron I'd angle-grind the soil pipe off flush with the wall, put on a connector and try it. The "dynamics" depend on the pan!
Back to top
 Alert Moderators
caffreys
from United Kingdom
PostPosted: Fri Jan 09, 2009 3:29 pm Reply with quote
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 447 times
PostPosted: Fri Jan 09, 2009 10:11 pm Reply with quote
cut the lead as near the wall as you can, you WILL scrape your knuckles, fit a multikwik "ext A" into the lead and cut to length and fit a multikwik 1/14(angled pan connector) onto pan or get a flexible ext pan connection and it will bend to suit
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Wobbly toilet suggestions? 2 1560 Thu Jul 26, 2007 10:34 pm
Stopcock handle just sheared off! Any suggestions?? 7 340 Tue Mar 01, 2011 7:51 pm
Halstead Ace High problem - suggestions welcome 2 120 Mon Apr 25, 2011 6:39 pm
Suggestions for replacing a Pulsa Coil 2000 5 80 Sat Jul 02, 2011 9:28 am
Shower next to window need screen suggestions please 4 120 Fri Oct 07, 2011 2:36 pm
DIYnot
