1 hot rad rest cold
12 Nov 2004
i have just permantly removed a rad, after filling the system bled the rads. (managed to get some warm at this point) but now back to only 1 warm rad upstairs.
second can\\\'t find central heating pump? system worked fine before
Please help, feeling cold.... :(
sounds like you have a one pipe system amd you cut the one pipe or you have introduced and air lock sowe where?
open the valves were you removed the rad to let any air out. If you put on stop ends then either replace these with manual air vents or remove the dead legs.
