DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
MSB Fault
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
pablospamio
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 8:25 pm    Post Subject:
MSB Fault
Reply with quote Thanks
Our ground floor lighting MSB tripped the other day, but when flicking the circuit back on, the lights have not come back on - i would have expected the MSB to trip again if there was a problem, but it remains in the on position with no lights on.
I would be grateful for any ideas as to what may have happened?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 12, 2004 8:28 pm    Post Subject:
you "spelt" it wrong so it is now offended
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 9:12 pm    Post Subject:
Re: MSB Fault
i would advise you call an electrician to come and install an MCB
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 12, 2004 9:26 pm    Post Subject:
These things are designed to trip even if you are holding the switch. So possibly if there is still a short on your lighting, then the mcb would have tripped again while you were trying to push it back on. This might have left it with the switch in the 'on' position, but actually switched off. I am told some mcb do this.
What was happening when it tripped? anything strange? did a bulb fail and cause it to trip? Anyone hammering in nails? mice eating wires?
Does it normally trip when a bulb goes? Again, was it a bulb failing which caused it to trip off. If it was, then concievably the mcb has worn out and just will not work. If there is no obvious explanation, then I would suspect the mcb is fine but you have a problem somewhere else.
__________________
His vorpal blade went snicker-snack
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fault Finding On A Ring Main Circuit 9 580 Tue Jul 29, 2008 9:44 am
Interesting Fault. 20 600 Tue Jul 29, 2008 7:56 pm
HELP - live to earth fault - where to begin? 25 700 Tue Aug 12, 2008 7:36 pm
hi-fi power supply fault? 31 800 Sat Jul 19, 2008 10:03 pm
Earth Fault Path 4 220 Sun Jul 13, 2008 9:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
