I see there are a few wood flooring experts on here so I thought I would pick your brains before i start work.
I have some Atkinson & Kirby Diamond Range Multi Layer Walnut flooring (link) which I intend to lay in the kitchen and hall way. I intend to lay this over the concrete floor with an underlay something very similar to link
The floor is currently covered with brittle vinyl style (marley?) tiles. These pop up quite easily leaving the nasty black bitumen adhesive behind. The floor needs levelling as the corners dip down by up to about 10mm.
I have popped a couple of tiles off and had a go at removing the nasty stuff before I came in search of help:
On the left is an attempt with a chiesel, in the middle was some white spirit and on the right was nothing at all... Heres a close up of the stuff...
Whats the best way to treat this stuff? There seem to be a whole host of recommendations out there from screeding over after priming to its got to be removed with a pointy tool and a load of elbow grease. After the small area I had a go at I'm not fancying scraping 15m2 off manually!
So I suppose my questions are:
1. Does it look too thick to prime and then screed over?
2. If I have to remove it by shot blasting the floor what type of "grit" would I use in the blaster?
3. What type of levelling compound is best to use? I spoke to Sika and then recommended using their latex levelling after removing the bitumen i'm assuming this is bad advice after the negative comments about latex compounds on here.
4. Have I chosen the correct underlay?
5. Is Atkinson & Kirby a reasonable make?
6. When laying in a kitchen am I taking the correct method of putting the flooring down first over the whole area and then installing the units on top?
7. I have found a couple of versions of there installation instructions, one mentions gluing the top edge of the groove over its entire length and one mentions gluing 100mm lengths every 600mm? Any advice on which is the best / correct?
Sorry for all the questions I just want to do a decent job!
