Fluffster
Joined: 05 Jul 2006 Posts: 971 Location: London, United Kingdom Thanked: 2 times
Posted: Thu Jan 15, 2009 9:42 pm Post Subject: Under floor heating control programmer burnt out |
A client who I am working for has a problem with her electric underfloor heating about 20msq under travertine marble in a basement kitchen.
After the cold weather last week she returned to her house to find the programmer had burnt out internally with carbon staining all over the pcb.
The 2.5mm cable from the consumer unit had the insulation sheathing melted around the contacts at the back too.
The unit is on a 20amp mcb and also an rcd. These had not tripped.
The wiring in the control box which is fed by the programmer for the underfloor circuits appears all correct and undamaged.
Any ideas as to what may have caused this to happen please?
The system was installed over a year ago and used on a daily basis during the colder months for about 8hrs a day.
Pete |
sparkyspike
Joined: 14 Jan 2007 Posts: 1673 Location: Sussex, United Kingdom Thanked: 17 times
Posted: Thu Jan 15, 2009 10:52 pm Post Subject: |
Do you know how many watts the mat runs at? If it's a 200W per sqm mat, was it fitted with a contactor? The contactor would allow more current to be used than the thermostat could otherwise handle. If a contactor hasn't been fitted, then the thermostat could have been overloaded, hence burning itself out. The 20A mcb or rcd would not necessarily trip.
Has a 13A fcu been fitted, or a 20A DP switch? __________________ Are those my feet? |
Fluffster
Posted: Fri Jan 16, 2009 8:35 am Post Subject: |
Thanks Spike much obliged.
I will advise her.
There is only a 20amp mcb no dp switch or fused switch inline either.
Pete |
sparkyspike
Posted: Fri Jan 16, 2009 9:17 pm Post Subject: |
Ok. If there's no fuse other than the 20A mcb, then it is likely to be a 4kW (17A) system, which will require a contactor. The thermostats you get in those programmers can only handle up to 13-15 amps. As the installer omitted the DP switch, then he probaby omitted the contactor too! __________________ Are those my feet? |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21986 Location: London, United Kingdom Thanked: 78 times
Posted: Fri Jan 16, 2009 11:34 pm Post Subject: |
Did the installer provide a certificate to say that it had been done in compliance with BS 7671? __________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth. |
