Joined: 12 Nov 2004 Posts: 94 Location: Ireland Thanked: 0 times
Posted: Mon Nov 15, 2004 1:14 pm Post Subject:
installing a vanity unit
My vanity contains 2 lights and a shaver socket which are operated by a pull cord on the unit.
I was planning on running 1mm sq cable from the ceiling rose into a fused spur which i was going to mount above my unit. The plan was then to connect the flex from the unit into the fused spur.
Is this a good solution or am I going about things the wrong way.
Posted: Mon Nov 15, 2004 3:27 pm Post Subject:
Wiring in a vanity unit to the bathroom
Is it suitable rather than using a FCU to join the cable from the ceiling rose to the flex of the unit using a terminal block and to track it into the wall or do you suggest another method?
Posted: Tue Nov 16, 2004 10:19 am Post Subject:
Wiring up a vanity unit
Are there different Amp sizes for a flex outlet (blanking plate).
If so what would be the correct size to use to run off my lighting circuit into the vanity unit.
Also is it OK to use 1.5 mm sq cable to run from my ceiling rose even though the rest of the circuit is running on 1mm sq cable?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
