Anybody tell me what this is from EOB5630 electric fan oven?
1 Feb 2009
Merseyside
Hi
Can anybody tell me what this is from Electrolux EOB5630 electric fan oven and how to replace it?
Also where the white wire should go?
Thanks in advance[/url]
That is a thermal switch which brings the cooling fan on a few minutes after switching on oven/grill.Without it the oven will overheat and switch itself off.
Thanks assuhors
Do you know the best place to get one for my oven and would I need a special tool (i.e. crimping) to fit?
Cheers
You don't need any special tools as the upgraded replacement comes with the wires attached.Try Partsmaster or Electrolux Spares.
Thanks again assuhors
I'll have a shop around and let you know how I get on.
Cheers for your advice and quick replies.
Just an update:
Ordered a new thermal cut out from parts master for £37 including next delivery and as assuhors so rightly stated it comes with cables and 'push ons' connected so a simple case of pulling off the old one and replacing with the new one (remembering where the cables came from and colours go on the correct connection).
This seems to be a common problem with these cookers but it's an easy fix.
Thanks to assuhors for his help
Cheers
