Hi guys, i am new to this forum and appreciate any help that can be offered as i'm really at my wits end with my central heating system. I have had a friend who is a plumber to trade look at and he has drawn a blank also!!
Open vented system with header tank in the attic
Potteron Suprima 80L boiler - PCB and stat have been swapped out last month but to no avail
8 K2 rads and one towel rail (upstairs bathroom), all rads have TRV's and were fitted along with new pipe work (Hep 10mm) 2 months ago.
New pump fitted last month, again no avail. System has been drained, de-sludger placed in system, drained again with inhibitor placed in system upon refill.
The problem i have seems to be that the heat is getting away from the boiler. When the boiler inititally fires up it stays on for around about 8 mins, then overheats. After this the boiler will come on for a minute or so then cut out for 2, back on for 1 and off for 2. It carry's on like for the rest of the time it is on.
The stat in the hall is set to 21 degrees, and i can safely say that this temp is never reached. The rads get warm but are by no means burning. Due to this it takes an age for any kind of heat to build up the house.
What i have noticed is that the flow coming out of the boiler is really hot, so hot you couldn't keep your hand on it, but the same flow pipe that goes into the pump under my stairs is luke warm at best just before it goes into the pump. The distance from the boiler to the pump is about 3 metres.
I disconnected the flow pipe from the boiler and from teh pump and blew through it, there didn't appear to be any blockages, i did the same with the return with the same results. Unfortunately i can't see the pipe from the boiler to the pump as it goes under a tiled floor.
I also noticed that the first rad (600 K2 in the hall) and the towel raile (highest point) need bled once a week at least. Not sure if that has any bearing.
Any suggestions as to what could be the issue here?
[/b]
[/b]
