Ariston LI 62 Light Flashing
18 Nov 2004
The extended cycle light on my Ariston LI62 flashes and does not wash. No water seems to pump in, the tap is on and there is no kink in the pipe. Help :confused:
i have the same model and have recently encounterd the same problem, did you find a solution to this problem?
many thanks in advance
phil
Please do not reply to old posts with questions such as "...how did you fix yours"
It is quite often the case the poster originally asked some months / years ago, and since found help elsewhere, and never come back, so they are unlikely to reply to you.
Before you post a reply, look at the date the post was origonaly made, and number of posts the poster made
The problem was that my filter had got blocked by stew! and had overflowed into the motor compartment = one new motor needed :oops:
