DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Whats the best way to cut right angles?
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
StaticPhilly
from United Kingdom
Thanked: 1 time
PostPosted: Wed Feb 04, 2009 1:02 pm Reply with quote
hi,
basicly im having a nightmare cutting the pelmets for the kitchen (the beaning stuff for the top and bottom of the wall units)
I was just wondering what the best way is to cut the right angles, i have a miter block but the corners still seem to have gaps in them.
thanks,
Philly
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 225 times
PostPosted: Wed Feb 04, 2009 1:22 pm Reply with quote
When you say 'pelmets' do you mean the trim at the top of kitchen units?
If so, I used an electric saw table, you can hire one, well worth it if you have a lot to do.
You would only need it for a day.
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Wed Feb 04, 2009 3:34 pm Reply with quote
Philly - 'cos you seem to be doing this job by hand I'm afraid that with alot of these things it comes down to skill-level and tool quality. You say you're using a mitre box (block) so just check the amount of 'play' each side of your saw blade ... I bet it wobbles. This 'poor' fit, linked to the workpiece maybe moving slightly (not clamped firmly/correctly), will result in your type of gaps.
Most kitchen fitters will use a compound mitre saw (electric) to produce these very accurate cuts. So to answer your question, "the best way" ... it's one of these. You have to weigh-up the manky finish to your kitchen trim (it'll always bother you) against the cost of hiring the equipment even if it is only for a couple of cuts. You can buy cheapo compounds (30 upwards) but these often come with the wrong blade for your type of work and others here have noted poor angle stop/lock. Factor in the cost of a new blade, maybe 30+
You can buy manual compound mitre saws for under 20 which, with a bit of practice, do the job just about OK but never as good as the electric jobbies.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1301 times
PostPosted: Thu Feb 05, 2009 12:33 am Reply with quote
A tenon saw and the piece placed firmly in a block, and the the saw pressed firmly against the side of the block when cutting, should give a straight cut.
Back to top
 Alert Moderators
StaticPhilly
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 05, 2009 9:59 am Reply with quote
thanks chaps,
yes the block was moving when i first tryed so i screwed it down, not as bad then.
i was thinking of a saw table (i can pick one up forabout 40) but my consern was that it might be to ruff and split the endges of the cut.
Diyisfun, yes i am onabout the trims.
thanks for your help, think i should get a saw table that dose 45 angles, feel like im cheating on my good old handsaws but never mind!
Back to top
 Alert Moderators
kjacko
from United Kingdom
Thanked: 41 times
PostPosted: Thu Feb 05, 2009 10:59 am Reply with quote
I don't know if you're confusing a 'table' saw with a 'mitre' saw, but i'd definitely be getting a small mitre saw for that job.
Cutting angles on a cheap table saw is a headache you'll want to do without mate tbh.
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 4 times
PostPosted: Thu Feb 05, 2009 11:07 am Reply with quote
http://www.itslondon.co.uk/pd_MAK110MLS100_MLS100_MakitaMitreSaw.htm
Weigh up what future use you will get out of it.
B&Q have had this item in store for about the same money.
All the sheds will have cheapies but a lot don't have positive angle stops which means you can cut a slightly wrong angle if not careful.
Back to top
 Alert Moderators
kjacko
from United Kingdom
Thanked: 41 times
PostPosted: Thu Feb 05, 2009 11:18 am Reply with quote
my 30 effort (max. cut of 115mm) from a diy store 5 years ago is still put to good use for pelmets and architraves. Cuts cleaner than my 130 sliding one with 280mm cross cut.
fwiw.
Back to top
 Alert Moderators
makitaman
from United Kingdom
PostPosted: Thu Feb 05, 2009 4:31 pm Reply with quote
A compound mitre saw would be the way forward, to really get a spot on mitre we also glue the mitre ends together with 'mitre glue', spray one end and glue the other hold together for about 10 seconds and job done.
Back to top
 Alert Moderators
Bloggsyboy
from United Kingdom
PostPosted: Sat Feb 07, 2009 8:16 am Reply with quote
Mitre chop saw is the way to go but if you have not used one before be very careful they are not as safe as handsaws. Make sure the workpiece is firmly held down and your hands and loose clothing well out of the way. Also watch out for slithers of offcut flying off at high speed and hitting you.
Good luck.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Whats the distinction between linings and casings? 2 840 Thu Feb 07, 2008 4:03 pm
Whats this hinge called please? 3 140 Tue Sep 24, 2013 6:53 pm
Door locks, catches and hinges - whats the easiest way? 5 160 Thu Dec 13, 2012 4:07 pm
dust masks - whats the difference? 2 100 Mon Mar 11, 2013 8:55 pm
Whats the best way to colour wood filler 6 120 Mon Nov 21, 2011 6:45 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
