DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Sealing a bath
This topic originated from the How to page called Tiling around a bath
Click here to return to the page called Tiling around a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Kajez
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 18, 2004 11:24 pm    Post Subject:
Sealing a bath
Reply with quote Thanks
I have just realised that my bath seal is leaking and is letting water through my walls. The problem is that the gap between my wall and my bath is quite big, so there isn't a nozzle that will fill it. I have heard that putting soaked newspaper in between the gap works, is this right???
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Nov 19, 2004 9:32 am    Post Subject:
You can buy many difference type of profile moulding for the bath sealant from tiles shop or any good diy shed will have them. Some of them do peel back putty type.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Bodge the Builder
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 21, 2004 10:45 pm    Post Subject:
I have a similiar problem and wondered whether you'd solved yours. Cos of uneven walls the gap between our bath and wall is as much as 20mm in places. I've tried to seal on top of newspaper but after a few days the sealant cracks and we get water running down the hall wall below. I've read about quadrant tiles and plastic coving but I've not found anywhere that sells these.
Back to top
 Alert Moderators
hilda
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 12, 2005 7:26 pm    Post Subject:
sealant on bath
how can i get old sealant of my bath, me hubby made a bad job, and he got it everywhere and it has stuck on me bath, i have tried scraping it off and spraying sealant remover on, to no avail :
Back to top
 Alert Moderators
simonh1024
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 12, 2005 9:58 pm    Post Subject:
First of all, is your bath a 'plastic' type?
If so, then before sealing the bath should have been over half filled then sealed so that the silicone was put in when the bath had a mid-way point for weight.
Secondly, if you had big gaps, you should have use the above method, plus before the silicone, used foam filler.....which is not the best thing.
Also, if the wife is cleaning the tiles with things like vilkie etc, this rots the silicone , as does most cleaning products.
There is a problem as to the squareness of old and new rooms. I did a bathroom only yesterday where the bath sat neatly into the corner, but as the short side went to the wall, it simpily went away by half an inch.
So, fill with foam filler, cut foam back down , fill with silicone, remembering that it will be a big wide joint, do it slowly, lots of water/washing-up liquid, press it down to get a nice finish. Do again a day later to get the best effect.
You can fill with silicone first time instead of foam, then do again the next day.
Back to top
 Alert Moderators
hilda
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 12, 2005 10:17 pm    Post Subject:
NO. THAT WASN'T MY QUESTION, THE PLASTIC BATH HAS BEEN IN MY BATHROOM FOR 9 YEARS, ITS JUST THAT WE HAD TO RESEAL IT, AND THERE IS SOME OF THE OLD SEALANT STILL ON THE BATH I NEED TO GET RID OFF, I KNOW WHAT YOU ARE SAYING ABOUT FILLING THE BATH HALF WAY, BEFORE SEALING IT, BUT YOU CAN SAY OUR PLUMBER WASN'T VERY GOOD AT COMMUNICATING BACK THEN, SO IF ANYBODY OUT THER HAS ANY BETTER IDEAS AT GETTING IT OFF, I WOULD BE GRATEFULL.
Back to top
 Alert Moderators
HandyJon
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 15, 2005 12:20 am    Post Subject:
Firstly don't SHOUT!
Taking off sealant is a labour intensive process. You'll just have to scrape it off. A stantley knife blade works well, but use it carefully. I find the type with snap off blades extended to maximum length out of the handle works well. Just scrape gently. You can also rub a dry finger over the left last fiew bits. Sealant remover is not very good and only really works on removing a film of sealant.
Back to top
 Alert Moderators
mrcrow
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 31, 2005 4:36 pm    Post Subject:
been browsing http://www.toppstiles.co.uk/
as i want something like this as well..and some covering strips for joins between disimilar tiles
hope its of some help...topps is near me.
__________________
light thickens, and the crow makes wing to the rooky wood.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
sealing a bath 2 980 Tue Jun 13, 2006 6:14 pm
Sealing the bath. Do length or width first? 8 1260 Mon Jul 16, 2007 3:56 pm
Sealing around the bath 2 1500 Thu Dec 01, 2005 3:49 pm
Sealing around a bath with a big gap 3 120 Fri Nov 06, 2009 1:40 pm
Sealing bath where it meets tiling..... 30 5060 Fri Jan 26, 2007 11:53 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
