DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Can't get the trip switch back on
Author Message
onebobo
from United Kingdom
PostPosted: Fri Feb 06, 2009 4:06 pm Reply with quote
Hi.
I wanted to move a bathroom pullswitch a few inches so turned off power and cut through cable.This caused the lighting circuit to trip and now it wont go back on.I have checked all the bulbs.
Any thoughts please.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 925 times
PostPosted: Fri Feb 06, 2009 4:12 pm Reply with quote
First thought......is we need more information.
Is the cable still just cut or have you re-connected the cable to the switch and if so how did you do it.
Back to top
 Alert Moderators
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Fri Feb 06, 2009 4:21 pm Reply with quote
Have you reset your RCD and any MCBs which may also have tripped? Is the earth wire in the cable touching either of the cut live wires?
Back to top
 Alert Moderators
onebobo
from United Kingdom
PostPosted: Fri Feb 06, 2009 4:34 pm Reply with quote
Hi.
The cut cable is not connected and the three wires are seperated and not touching.I have power to the sockets but no lights.The RCD is a Hager.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Fri Feb 06, 2009 4:35 pm Reply with quote
Back to top
 Alert Moderators
onebobo
from United Kingdom
PostPosted: Fri Feb 06, 2009 4:44 pm Reply with quote
I turned off the lighting trip switch and cut the cable.
This caused the main switch to trip which i have switched back on but the lighting switch won't go back on.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Fri Feb 06, 2009 4:48 pm Reply with quote
Oh right, the RCD tripped when you cut through the cable, this is quite normal.
How many wires were there in the old switch? How have you connected them back up? A photograph too will help.
Could be that the MCB is shot at, you have put a screw through the cable or wired it wrong. You haven't put the earth into COM, L1 or L2 have you?
I suppose this would trip the RCD tho.
Back to top
 Alert Moderators
onebobo
from United Kingdom
PostPosted: Fri Feb 06, 2009 4:53 pm Reply with quote
It's not wired yet.
I have left the cut cable sticking out the ceiling with the three wires apart and not touching.It was all working fine before and i can't see what the problem could be as it's not connected.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Fri Feb 06, 2009 4:56 pm Reply with quote
Can you get above to check the cable? Is there a possibility that there was another cable entering the switch?
Don't leave bare wires sticking out of the ceiling too, put them into chock block and enclose in a chock box so it can be energized safely.
Back to top
 Alert Moderators
onebobo
from United Kingdom
PostPosted: Fri Feb 06, 2009 5:07 pm Reply with quote
There is no other cable.
Perhaps the fault is somewhere else ?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Fri Feb 06, 2009 5:10 pm Reply with quote
Perhaps, more likely you have disturbed something. Could be the other end of the switch cable - have seen a mass of moltern plastic above a bathroom light before.
Alternatively it might be the MCB which has failed internally.
Back to top
 Alert Moderators
onebobo
from United Kingdom
PostPosted: Sat Feb 07, 2009 2:49 pm Reply with quote
Thanks.
Turns out it is a faulty MCB.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Electric tripped & trip switch won't turn back on, Pls H 14 20520 Sun Jul 22, 2012 9:03 am
Bedroom lights trip switch won't go back on. 4 180 Sat Jan 03, 2015 6:53 pm
Some lights wont come back on after trip reset 4 180 Thu Dec 04, 2014 8:18 am
Outdoor Lighting - Separate Ring / Trip switch? 5 721 Thu Apr 05, 2007 10:40 pm
Seperate trip switch for cooker & shower 5 60 Sun Sep 11, 2011 9:57 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
