DIYnot
Local | Network
   DIYnot > Forums
Local | Network
fitting stone resin shower tray
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
darren bergin
from United Kingdom
PostPosted: Sat Feb 07, 2009 12:31 pm Reply with quote
Just about to fit a stone resin shower tray onto wooden t &g floorboards
Can i place this tray direct onto floorboards held with mastic, or should i make a wooden frame & base for it to sit on?
i hear tilng should be done afterwards for a more waterproof fixture
any help appreciated before i plough ahead
ta
Back to top
 Alert Moderators
Prof.plumb
from United Kingdom
Thanked: 4 times
PostPosted: Sat Feb 07, 2009 12:37 pm Reply with quote
has it got legs are are you laying it flat to the floor?
Back to top
 Alert Moderators
darren bergin
from United Kingdom
PostPosted: Sat Feb 07, 2009 12:59 pm Reply with quote
it lies flat to the floor
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Sat Feb 07, 2009 1:06 pm Reply with quote
what are you doing on the rest of the floor ? tiling etc.
have you made an access in the floor to join the pipe to the trap ?
what do the mi's say ? follow what they recommend or your warranty won't be worth the paper its on.
is it the 4" t&g flooring thats down or larger floorboards ?
Back to top
 Alert Moderators
darren bergin
from United Kingdom
PostPosted: Sat Feb 07, 2009 2:40 pm Reply with quote
yes i just want to lie it flat on normal floorboards
i want to fit waterproof laminate boards for the rest of the floor in bathroom
what should i use on base ? some sort of mastic?
i can run the laminate boards under the shower if need be
will it be better to lay shower on the laminate boarding ?
same principle applies though how do i fix it down
thanks
Back to top
 Alert Moderators
swidders
from United Kingdom
PostPosted: Sat Feb 07, 2009 5:12 pm Reply with quote
Mortar - sand and cement. Reasonably wet mix straight onto floorboards. Tap gently around edges (pref with rubber mallet) to ensure level and bedded in. Leave overnight
Laminate after - will cover the mortar showing at bottom rim of tray.
Back to top
 Alert Moderators
darren bergin
from United Kingdom
PostPosted: Sat Feb 07, 2009 5:49 pm Reply with quote
cheers swidders
thanks
so gripfill is a no no
Back to top
 Alert Moderators
swidders
from United Kingdom
PostPosted: Sat Feb 07, 2009 6:05 pm Reply with quote
Correct - it needs to be able to support the weight while you level it and it goes off. If you like, you could use floor tile adhesive, but I keep to wet, soft buttery consistency mortar - 3, 4 or 5 parts builders sand to 1 part cement (with a bit of washing-up liquid or plasticiser squirted into the water first).
Remember to get the rim level, not the base of the shower - it will have a run-off slope incorporated into its design.
Finally, if you can, squirt a load of cheap sanitary sealant between the sides and the wall to help create a full seal.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitting a stone resin shower tray 7 560 Fri May 14, 2010 9:04 am
Fitting a stone resin shower tray onto concrete floor 3 2260 Fri Feb 05, 2010 10:23 pm
Fitting Stone Resin Shower Tray 15 6020 Sat Jun 09, 2012 12:11 pm
Stone Resin Shower Tray 4 80 Mon Mar 11, 2013 1:16 pm
Stone resin shower tray on 4x2 timber 6 220 Mon May 11, 2015 6:10 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
