Help !!! low water pressure light on, no CH.
19 Nov 2004
I\\\'ve got a Potterton puma 80 and the low pressure light is on. How do I go about sorting this out. I have tried to up the pressure with the refill value at the bottom of the boiler but this hasn\\\'t worked. I\\\'ve tried bleeding the rads upstairs but this has failed to. Its getting very cold in my house !!!!!!!
Common fault on potterton puma/combi 80, the problem is the actual low water pressure switch, this is located behind the printed circuit board screwed into the diverter valve.
The easiest instant cure is to remove one of the 2 wires going to the switch.
the long term cure is to drain the system remove and clean/replace
hope that is of help to you
jon
"The easiest instant cure is to remove one of the 2 wires going to the switch. "
That could leave a dangly live end.
Better to unplug the switch leads' plug from the pcb. A twin one, lower left of the board. But don't leave it like that; a new switch isn't expensive.
obviously you wouldnt leave a "dangly live end"!! you would use electrical insulation tape and tape it up, the wire is in a insulated spade connection anyway and unlikely to cause a problem.
Firstly Remember this is only a temporary measure to get heating tonight.
And secondly i would not reccomend an untrained person to start fidlling woth p.c.b`s
the low pressure switch is very cheap and i reccomend you get a heating enginner to sort the problem
[/quote]Firstly Remember this is only a temporary measure to get heating tonight.[/quote]
Thanks gasman - this has got me out of a sticky situation tonight and saved an expensive out of hours call-out!
