Yesterday had a new combi fitted (Worcester Greenstar 24i Junior). Shower pressure is unacceptably low and certainly lower than the old glow worm 75e boiler.
Only change I can see is that because the fitter couldn't find the house stopcock he sliced the cold inlet to the boiler and put an isolation valve on.
Now I've seen some posts suggesting that this arrangement may drop the bore from 22mm to 15mm (internally), though no definitive answer.
Question therefore: Would it be recommended to ask (he comes back today) for him to fit a gate valve instead or might something else (also?) be causing this?
NB cold inlet pressure is fine across the house (unchanged).
Any help much appreciated.
Thanks.
Thanks.
