DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vokera Maxin 24e Hot water problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
sfa1973
from United Kingdom
PostPosted: Mon Feb 09, 2009 2:21 pm Reply with quote
Hi All
My Vokera boiler has started playing up. Fo a month or so the hotwater stops working (Comes out cold), although if the heating is on then no problem it seems to work fine. As soon as the timer switches the heating off then the problem occurs again, just cold water boiler doesn't fire???
This does not happen all the time though, some days it works absolutly fine, other days if you turn the hot water on full (flow through the taps) then it runs stone cold, reduce the flow and the hot water starts to come through again.
Any ideas please and solutions or tests i can perforn to diagnose properly??
Vokera Maxin 24e
Approx 6 years old
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 130 times
PostPosted: Mon Feb 09, 2009 4:14 pm Reply with quote
I've had a very similar problem on a 'halstead' boiler.
The first bit of water was warmish when heating on, because it was static in the heat exchanger,
Without the heating on it was cold and boiler would not light.
The fault was a perished 'diaphragm' in the 'switch assembly housing'.
This 'diaphragm' when in good order pushes on the diverter valve and this diverts the water through a heat exchanger instead of the radiators.
When the diverter valve moves across, it also triggers a micro switch to light the boiler.
A replacement 'diaphragm' has cured it. So I guess you have same type of problem.
Back to top
 Alert Moderators
sfa1973
from United Kingdom
PostPosted: Mon Feb 09, 2009 4:24 pm Reply with quote
Thanks for that.
I was thinking the same and its the cheapest option as parts go so worth a try.
Best go shopping then.
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 130 times
PostPosted: Mon Feb 09, 2009 4:29 pm Reply with quote
Strangely enough it was a vodera diaphragm I used (4)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera Maxin 24e problems 5 80 Wed Nov 23, 2011 8:35 pm
Vokera Maxin 28e hot water hot then cold then hot 10 920 Sun Nov 11, 2007 9:01 am
Vokera maxin 24e water leak 2 1660 Sat Mar 10, 2007 10:23 am
Vokera Maxin 28e - intermittent hot water 8 1500 Thu Mar 09, 2006 9:58 am
Vokera Maxin 24e combi boiler - no hot water 4 120 Sun Aug 12, 2012 12:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
