DIYnot
Local | Network
   DIYnot > Forums
Local | Network
WORCESTER 28CDI NO HOT WATER!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
KATIEKINS
from United Kingdom
PostPosted: Sun Feb 15, 2009 10:29 am Reply with quote
Im looking for some advise, i have a 28cdi boiler and cant get any hot water its been like this for 2 days now. luckily I have homecare with british gas so any repairs are not going to cost anything but i have had 2 engineer visits and the diverter valve has been replaced but there is still no hot water?? The engineers are now trying to say that we dont have enough water pressure, but our pressure at the prop although low has not changed in the 10 years we have been here and the boiler has worked ok for the 6 years its been in? I have a new visit booked for tomorrow so would like to know if anything else could be causing the problem? I dont want to end up being trampled on by a bolshy engineer!!
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5248 times
PostPosted: Sun Feb 15, 2009 10:37 am Reply with quote
Flow differential assembly needs attention probably.
Back to top
 Alert Moderators
fitz1
from United Kingdom
Thanked: 20 times
did he check thermistor.
Back to top
 Alert Moderators
mogget
from United Kingdom
Thanked: 108 times
PostPosted: Sun Feb 15, 2009 11:42 am Reply with quote
KATIEKINS wrote:
I'm just a householder, so I'll ask the RGI's - if the flow has always been marginal, could crud in the plate heat exchanger be the cause?
Back to top
 Alert Moderators
powermaxer
from United Kingdom
PostPosted: Sun Feb 15, 2009 12:03 pm Reply with quote
if they want to charge you for a powerflush,show them the door pronto.
Back to top
 Alert Moderators
diy
from United Kingdom
Thanked: 1 time
PostPosted: Sun Feb 15, 2009 12:53 pm Reply with quote
Have they checked the microswitch on the diverter to see if its making in hw mode.
Back to top
 Alert Moderators
SteveZodiac
from United Kingdom
PostPosted: Sun Feb 15, 2009 3:08 pm Reply with quote
I had my diverter valve replaced a couple of months ago and the engineer also replaced the water to water heat exchanger because it was scaled up and reducing the flow. Perhaps they don't want to do this as the part is expensive.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester 28cdi -No hot water. 2 700 Wed Dec 07, 2005 2:10 pm
worcester bosch 28cdi hot water temperature not constant 15 9140 Sat Dec 17, 2005 6:02 pm
Worcester 28CDi Hot water issue 5 1000 Mon Jun 01, 2009 9:17 pm
Worcester-Bosch 28CDi - No Hot Water Flow to Taps! 3 300 Sun Nov 28, 2010 9:47 am
Worcester 28CDi Water cycling hot/cold. Water leak from AAV 2 20 Wed Sep 26, 2012 11:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
