DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ariston Microgenus 27 leaking motorised valve
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Whiteye
from United Kingdom
PostPosted: Sun Feb 15, 2009 12:11 pm Reply with quote
We have an Ariston MicroGenus 27 boiler fitted in our house, the motorised valve is leaking, the leak appears to be coming from the upper casing, when I removed the electrical connection the water appears to be pooling through the 3 prongs on the motorised valve and running down the diverter valve body and dripping out of the bottom of the boiler.
Is it simply a case of unclipping the (now rusty) spring clip, removing the motorised head and replacing with a new part and spring clip or is there something more sinister going on? I'm assuming I will need to drain the system down before replacing the motorised valve?
Thanks in advance...
James
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1168 times
PostPosted: Sun Feb 15, 2009 1:13 pm Reply with quote
Bit more to it than that icon_smile.gif and often as result of poor or contaminated system water (eg cleaner chemical left in).
So far you've been lucky. Often if the motor head is wet the actuator switches inside become waterlogged and blow the pcb fuses.
The gland seal on the brass diverter block is leaking. Check the thermister pins below have also not corroded.
The best course would be to replace the brass diverter valve, however you may be able to swap just the gland seal although I don't recommend it.
If you carefully prise apart the motor head you can dry it out. If the spring clip is too rusty it will need replacing. If Ariston don't do it as a seperate part get it from Biasi.
You will need to drain the boiler, check/re-charge the expansion vessel, replace the auto air vent if there is any sign of leakage. The new diverter (flowgroup) won't come with the "main circuit flowswitch" assembly. This is the assembly on the front. Replace that as these often leak.
You will also need 4 plate heat exchanger O rings and it's worth getting a couple of bypass O rings. The other diverter seals are standard 1/2 and 3/4 fibre washers.
Back to top
 Alert Moderators
Whiteye
from United Kingdom
PostPosted: Sun Feb 15, 2009 8:21 pm Reply with quote
Thank you Gasguru, some very helpful info there, seems like there's quite a bit of work to do, but cross-referencing it with the boiler instructions it should be pretty straight forward.
As you say, I think we've been quite lucky as we've caught it before the water shorted anything out and started blowing the fuses on the PCB.
I may, if it's OK post again once the parts have arrived and I begin stripping & replacing things.
Cheers!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ariston Microgenus 27 MFFI? 2 1300 Wed Jan 11, 2006 12:08 pm
ariston microgenus 23 combi boiler problem 3 1240 Tue Apr 29, 2008 7:15 am
Ariston Microgenus II / Hot Water problem 2 780 Thu Dec 29, 2005 5:53 pm
Ariston MicroGenus Boiler behaving like a spoilt child..HELP 4 1760 Fri May 30, 2008 1:07 pm
Help! Damsal in distress..... Ariston MicroGenus HE 3 480 Sun Apr 27, 2008 9:50 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
