H
hernia
boiler will not ignite,flashing l.e.d. indicates lockout this happened after boiler was turned off at mains any ideas on to get boiler back on line
age of boiler poss.3 to 4 year old model linea 124kevplumb said:model age /boiler not you might help
then again if your that way inclined
the number 7 is flashing never tried changing thermo yet but will try bleeding the radiators thanksweargas said:there will be a number flashing at the same time as the led what is it?
number 7 is the number flashing will try bleeding radiators and check thermo coupling, cheersweargas said:there will be a number flashing at the same time as the led what is it?
thanks for your advice will change thermistor and won't bother looking for thermocoupleweargas said:your primary thermistor has gone. vokera part no 8484.
you haven't got a thermocouple on your boiler.
the "bleeding radiators and thermocouple" bit is my signature and appears in every post i make. it's a little joke for the other engineers on the forum.
advice was spot on,cheers now can you tell me how long it would take to change a d.h.w. heat exchangerhernia said:thanks for your advice will change thermistor and won't bother looking for thermocoupleweargas said:your primary thermistor has gone. vokera part no 8484.
