Hi I have to build a fence and I want to do the first few posts slightly different to the rest.
The first post needs to fit to the corner of my extension, can anyone tell me the best way (I am using 4" x 4" posts)?
I thought of coach bolts or studding but not sure how to fix the studs to the wall. Which is the best way to fix the post do you think?
The next 3 posts I want to fix into the ground with repair spurs so that the wooden posts can be removed more easily. How far into the ground do they need to go if the fence is 2m high?
I see they have 3 holes on most of the 4' spurs, do I need to use all 3 and wont one be too low ie in the ground if I sink this spur the usual 80cm underground as I read somewhere?
I was thinking of using studding for these spurs ie drilling right through the post but they do sell coach type bolts but these seem to only go into the wooden post 2" and we get strongish winds here so I fancy the studs, what do you think about this?
Finally, in the end I will have to do about 22 posts, probably a silly question but how does this ready-mixed-one-post-bags compare with mixing my own?
Should I just buy and mix my own cement and what mix is best please?
Also I have read somewhere to put the post in and fill around the bottom with gravel to help support it is this right or should the whole hole be full of concrete?
Also how close to the surface/soil do I go with the concrete?
Sorry for all the questions but I have read so many different things now, I am getting more confused now.
Any help appreciated.
