DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester-Bosch Wireless Digistat Problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
shakeydave
from United Kingdom
PostPosted: Wed Feb 18, 2009 7:09 pm Reply with quote
I've searched the forum already and found that someone has had the same issue as me but there wasn't any conclusion so rather than me explain it all again this is the link to the previous guy's message:
[url]
http://www.diynot.com/forums/viewtopic.php?t=122087&start=0&postdays=0&postorder=asc&highlight=[/url]
The forum rules ask for the following info:
1) Boiler make / model (gas or oil)
Worcester/28i junior Gas Combi Boiler
2) What is / is not happening.
The wireless Digistat is not starting the heating (see further info below)
3) Has ANYTHING else been done or changed recently.
Just changed batteries in Digistat Transmitter
4) When did the problem start?
After changed batteries - wouldn't re-initiase rf connection
5) When does it happen? eg, heating coming on or going off.
Doesn't come on
6) Anything else you feel may be of relevance.
So, I changed the batteries of the Worcester Digistat Transmitter (to the letter of the instructions), then tried to re-initialise the rf connection by pressing the receiver buttons 1&2. Saw the correct quick flash of the red LED but then it goes solid red permanently an the Digistat Flame symbol coming on doesn't fire up the boiler
The forums I've read so far all seem to point to a faulty Receiver, I just don't understand why it would fail from simply losing it's signal when I changed the batteries in the Transmitter.
Are there any checks I can do on the PCB of the Receiver to see if it has indeed developed a fault (I'm from a technical background with electronics experience) no good without drawings or known voltages at key test points.
It still fires up the boiler when I press Overide.
Have got pics of Transmitter and Receiver in situ if that helps?
Any help gratefully received.
ps Sorry for long post.
Back to top
 Alert Moderators
cider
from United Kingdom
Thanked: 580 times
PostPosted: Wed Feb 18, 2009 7:28 pm Reply with quote
Did you wait for the flashing lights to stop on the receiver before you re- installed the batteries?
Back to top
 Alert Moderators
shakeydave
from United Kingdom
PostPosted: Wed Feb 18, 2009 9:56 pm Reply with quote
Seriously, I could kiss you! Mate I don't know how I didn't try that before but it just worked - you've saved me 200 and a whole lot of grief off the missus for wasting money!
I shut it all down took the batteries out, fired it up, pressed/held button 1, pressed button 2 - quick Red LED flash then went out for the first time.
Put the batteries in and hey presto. Boiler fired!
Great job, thanks for the help!
Dave.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Drayton Digistat Wireless problem 2 320 Wed Oct 27, 2010 5:30 pm
Drayton digistat RF2 wireless problem 7 1660 Sun Sep 19, 2010 3:23 pm
Drayton Digistat RF3 Wireless thermostat problem 7 1100 Sun May 02, 2010 11:21 am
Drayton digistat RF2 wireless system - PROBLEM! 6 3760 Tue May 06, 2008 8:09 am
Replace wired Drayton Thermostat with Wireless RF3 Digistat 4 1680 Sun Oct 26, 2008 10:42 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
