DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Circuit breaker tripping intermittently.
Author Message
worcester4x4
from United Kingdom
PostPosted: Fri Feb 20, 2009 2:48 pm Reply with quote
This started about an hour ago.
The CU trip switch controlling the lounge and dining room rings tripped with a loud bang. I heard it from two rooms away!
I attempted to reset it but there was an immediate visible flash from behind the breaker and it tripped out.
I turned off all power at the main switch, then reset the trip then turned the mains power back on, everything was fine. Five minutes later, bang - the trip cut out again. I unplugged everything from the rings and reset. I then plugged everything back in one by one with a time interval in between but everything remained fine. Five minutes after I plugged everything back in - bang again!
I repeated the procedure. It's now been 15 minutes, everything is plugged back in and all is OK. I'm waiting with bated breath now.
Can anyone offer any potential explanation for this sudden strange behaviour?
Pete
Back to top
 Alert Moderators
rebuke
from United Kingdom
Thanked: 25 times
PostPosted: Fri Feb 20, 2009 2:53 pm Reply with quote
Is the breaker that's tripping an MCB (Miniature Circuit Breaker), or an RCD/RCCB (Residual Current Device / Circuit Breaker). The easiest way to tell if it's not labelled specifically is an RCD/RCCB should have a test button on it...
Back to top
 Alert Moderators
worcester4x4
from United Kingdom
PostPosted: Fri Feb 20, 2009 2:54 pm Reply with quote
Update:
It just tripped again for no reason that I can fathom.
Back to top
 Alert Moderators
worcester4x4
from United Kingdom
It's an MCB
Back to top
 Alert Moderators
worcester4x4
from United Kingdom
PostPosted: Fri Feb 20, 2009 3:06 pm Reply with quote
Well, short and sweet but I found the problem.
The ferocity of the trip implied to me that it must be a major short so I wandered around sniffing the sockets! Sure enough one smelt 'ozoney / burnt rubbery'. I took the faceplate off and found that the insulation on one live wire was broken and it was 'leaking' to earth. Why it didn't blow immediately every time, and why this happened on a socket that's been in situ untouched for about five years I don't know.
Anyway, I'm confident that's that and sorry to clutter up the board with what turned out to be a mundane and obvious problem.
Pete
Back to top
 Alert Moderators
Click-Sure
from United Kingdom
Thanked: 11 times
PostPosted: Fri Feb 20, 2009 7:09 pm Reply with quote
Id hazard a guess that as the cable expands and contracts as a result of the heat that builds up as a result of loadng on the circuit it is moving close enough to create an arc between the live wire and the earthed back box, which causes a massive leak to earth resulting in your MCB tripping intermittantly.
The reason this has just occoured is probably because the cable has been rubbing up against the back box under load for some time, and has only recently work through enough to cause a short.
I bet if you'd left all of your appliances unplugged it wouldn't have happened.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Fri Feb 20, 2009 7:12 pm Reply with quote
Why?
Back to top
 Alert Moderators
worcester4x4
from United Kingdom
PostPosted: Fri Feb 20, 2009 7:18 pm Reply with quote
I think you're probably correct.
Certainly had me guessing for an hour or so. All is well now though icon_smile.gif
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Neff over intermittently tripping out circuit breaker 3 880 Sun May 11, 2008 3:08 pm
NEFF oven intermittently tripping circuit breaker 12 4600 Sat Aug 06, 2005 6:08 pm
Intermittently tripping RCD - any ideas? 16 1420 Sat Nov 19, 2005 9:25 pm
mcb and rcd tripping intermittently 19 1480 Sun Dec 03, 2006 8:18 pm
Oven tripping RCD intermittently. 39 540 Fri Oct 18, 2013 12:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
