I have recently had a Vitodens 200-W system boiler fitted, which has very little useful programming facility in its controller. I have no room stat and no way of programming a timed reduced room temp on the boiler - other than the very crude settings available for an overnight temp - and I would like to fit some digital radiator valve controls to make up for the programming deficiencies.
I could fit the Honeywell CM70 setup, but this costs about £500 plus fitting, so I have sourced some standalone Honeywell Rondostat HR 20E valve heads in Germany, with digital time and temp control, I can get 6 for about £200, and they would do my lounge and bedroom rads, which is where we need timed control. Honeywell say that they are not approved for use in the UK as they do not have a boiler interlock as required by building regs. However, having only 6 out of 20 rads fitted with timer switched valves would have little effect on the boiler. After all, it is only the same as me switching them off manually. I would hope that if I have one rad elsewhere fitted with ordinary locksield valves, or fit a bypass, this should be sufficient. The boiler literature suggests that only the combi version of this boiler is fitted with an internal bypass.
Can anyone advise as to any other problem with fitting these valves? Incidentally, it seems strange that you can buy these valves for use in Germany, home of Viessmann!
This boiler is very efficient, but is basically designed to give constant temp in the house all day, which I suspect very few people require. It is also unable to heat CH and HW simultaneously, and HW always has priority. It has several fancy facilities on the programmer, most of which are of little use. If you wish to have a boiler with full control of time and temps, I would not recommend this model, efficiency and build quality notwithstanding. I suspect that if Viessmann wish to sell well in the future, they will have to offer proper temp and timing controls.
