DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
pitch of roof
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
climber101
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 24, 2009 9:51 pm    Post Subject:
pitch of roof
Reply with quote Thanks
for my planned ground floor extension (approx 3mx7m) I calculate the hipped roof pitches required to be between 14 to 15 degrees. (I reckon I can’t make the pitches any higher because I then reduce the roof flashing ‘upstand’ too much at one of the the sloping end pitches of the hip roof slope too much at corner of upper window)
Is that a lowish pitch or sound fairly common for extension I describe? (curious because it sounds low pitch to me)
Assuming I can find a match to my existing tiles that can handle that pitch with whatever overlap required could you advise please whether at that pitch is it common
a) to find tiles that will handle that pitch and ?
b) common to be having to put in extra defences against rain or not ? like double layers of breather fabric? and whatever else.
Many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 72 times
PostPosted: Tue Feb 24, 2009 9:54 pm    Post Subject:
15 degrees is shallow but still within the tolerance of some interlocking concrete tiles.
What tiles are on the existing building?
Back to top
 Alert Moderators
climber101
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 24, 2009 10:04 pm    Post Subject:
thanks noseall, sorry I don't have a more precise description as yet but they are red concrete interlocking ones that look "wavy"! house is only 9 years old so believe they would be of a more 'modern' type
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 52 times
PostPosted: Tue Feb 24, 2009 10:47 pm    Post Subject:
This has been covered ( icon_rolleyes.gif ) in the roofing section
Also some wavy tiles go down to a lower pitch than others
And don't design a roof pitch based soley on trying to acheive a flashing upstand by a cill. There are methods of detailing a tight cill/roof junction
Back to top
 Alert Moderators
climber101
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 24, 2009 11:08 pm    Post Subject:
thanks woody, i am intrigued with your comment about detailing a tight cill/roof junction so will go looking for any details of this . Currently where one of the side pitches is near to one corner of window cill i had left a bit over 150mm for upstand so if i can reduce this somehow to be tight to cill i reckon i can improve pitch up to 17 degrees.
Also some of the houses i have looked at dont seem to have a full length tile under the flashing at this interface? and the flashing seems to dip a bit making it look like i might not need the flashing to go as high as i think (didnt explain that too well)- i will try to find details of where you place top tile before putting flashing on etc.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Query Over Application of Screwfix's Pitch Roof Insulation 7 800 Sun Jan 09, 2005 5:47 pm
slate roof pitch 4 680 Mon Feb 19, 2007 4:35 pm
minimum roof pitch? 2 5560 Sat Feb 18, 2006 2:07 pm
What size RSJ for garage roof 49 1440 Wed Jul 23, 2008 4:14 pm
Roof Insulation 5 200 Sat Aug 02, 2008 12:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
