Hi everyone, I have used these forums a lot to help me over the years but this is my first post.
I have recently removed my electric shower and fitted a mixer shower with shower pump (salamander CT75). It has a direct feed from my cold water tank and the hot water cylinder as instructed. The problem is there is not enough pressure to keep the pump running constantly. Turning the shower to full cold or full hot makes the pump run fine but at my preferred temp it cuts on and off all the time. With the pump switched off the water only just dribbles out the shower head. If I disconnect the outlet pipes from the pump it flows through the pump quite fast though. I think the problem is the height of the shower head compared to the water tank (shower head is directly below the tank). Anyway it is only a 25l tank in the loft and due to the shallow pitch of my roof it cannot be mounted any higher. My question is would adding a 2nd 25l water tank beside the existing one increase the pressure or is there any other way to do this?
