System appears to be a 'Y' plan, with a Potty Flamingo RS keeping things warm. Everything appears to have been running as it should for years.
A couple of years ago the room stat was changed for a more sophisticated one. The original timer was left in place to control the hot water only.
Recently, a change in hot water use has resulted in the heating running despite the room stat showing satisfied.
When the room stat is satisfied the pump stops, the 3 port valve moves from'H' to 'M', and the pump re-starts, under control of the cylinder stat, and the heating continues to run until the cylinder stat is satisfied. The valve then returns to 'H' and the pump shuts down. By this time the house is much too hot.
The lever on the valve head moves easily by hand to all three positions, and I can hear the switches operating in the head, but it never moves to 'W' of it's own accord.
I suspect the 3 port valve, but cannot rule out pre-existing problems just highlighted by the change in hot water use.
The valve head is blue plastic, marked 'BGMVSP-23'
Before I get the multimeter out, and start prodding around, Where would you start? What electrical conditions need to be met for the valve to move to 'W'?
