Blocking up tile vents
7 Aug 2007
Surrey
I have 3 tile vents in the loft area. Its only used to store stuff and the floor has been isulated with rockwool and boarded in some areas.
Ive now attached the bathroom extrator fan to 1 vent which leaves 2 open.
After talking to my friend over the weekend he said that the vents are only needed if there is someone living in the loft space.
Questions is can i simply block these up? It gets very cold up there and im sure it cant help with the temperatures on the lower levels
Thanks in advance
The roof space is ventilated to help prevent condensation in there. The water vapour comes up from the house.
the loft space is supposed to be cold............it means your insulation is doing its job.
did you not think it strange that several million houses have been built with unnesesery vents in the roof :D :D
just mention that anyone silly enough to block up air vents had better check all the roof timbers for rot ;)
