Wash Basin Trap adapter ?
22 Jul 2007
Cornwall
Hi folks,
I have to replace the basin in my bathroom.
The existing outlet pipe is 1⅛"(external) copper and goes down to (& into) the concrete floor.
The basin already has a 1¼" waste.
The old - brass - 'S' trap did match these two sizes.
Is there anything around today to do the same thing ?
I would prefer a plastic 'S' trap that is adapted/able, but I have room to adapt the 1⅛" outlet pipe if I have to, before using a standard 1¼" trap.
Thanks for reading.
F
Thanks BAHCO:
As in my original post, the 28mm copper outlet pipe goes into the concrete floor - so for the time being, changing it all isn't an option - maybe in the future.
On re-reading my post, I think it ought to read:
"Adaptor from 28mm copper to 32mm plastic" needed !
There is possibly a 32mm 'S' trap with reduced out-let (to 28mm) already out there,,,,, it's just a matter of finding one in time.
thanks again
Hi.
An expensive way might be to increase the 28mm to 35mm copper with a copper adaptor.
32mm waste has an external diameter of about 34mm, so you might be able to then fit a compression waste.
Andy.
