- Joined
- 27 Jan 2008
- Messages
- 23,627
- Reaction score
- 2,661
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Charge control of 12 volt solar panels.
To use a solar panel as a stand alone unit is not a problem. The controller is basically a heat sink which converts any energy not required into heat and keeps the voltage within parameters.
However when used with other charging units this seems to be a problem. As the battery voltage is monitored to select charge stage.
Traction battery chargers work on a three stage system at first max amps is pumped into the battery then once the battery reaches approx 15 volt it triggers next stage which is a constant voltage charge current is now the trigger and once it reduces to a pre-set level the voltage is reduced to float charge at 13.6 volts.
See diagram
If one either uses the battery or charges the battery during the cycle it will change the point at which the stages change.
Using power is likely to delay the point of change but charging is likely to advance the stage so adding a solar panel charger would need to be in some way integrated into the system.
If the panel output was below 15 volt then during the main part of the charge cycle it would only produce heat and not help at all. On the other hand if producing 15 volt once the float charge part of cycle has been reached it would over charge the battery.
Using a small output panel with no control may be an option relying on the fact that more than it’s output is being used daily buy water pumps, lights, etc. And on the odd time it overcharges then the equalising charge is likely to do more good than harm with batteries where the water level can be topped up.
Assuming some light on the main charger to indicate stage of charge I would think one can produce a charge limiting device with a variable output.
But with a switch mode battery charger there is no need for the smoothing capacitors etc used in normal switch mode supplies and it can use far better control by monitoring the voltage between charge pluses.
So I am unsure of what effect the charge from a solar panel will have on the main charging unit.
I have read Design Trade-offs for Switch-Mode Battery Chargers with interest and this is what alerted me as to likely problems. I am waiting for my son to send details of charger used I know it is switch mode 5 stage and 50 amp but no more details at this moment.
I am sure other people must have faced these problems and maybe there is already some answers?
See diagram
