DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking Shower Screen
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
LivvyB
from United Kingdom
PostPosted: Sat Mar 07, 2009 6:41 pm Reply with quote
I wondered if anyone had an ideas on a leaking shower screen.
It's driving me mad!
I admit I'm no great DIY'er... I can paper and paint and basics like that.
I had lot of building work done on my house and had a new bathroom fitted.
A while later I had a new shower and glass screen put in.
It leaks all the time, the floor is soaking wet again today.
It has been sealed by tradesmen several times but still seems to leak.
Any ideas from anyone on a cure?
Libby
Back to top
 Alert Moderators
petetheleak
from United Kingdom
Thanked: 1 time
PostPosted: Sat Mar 07, 2009 6:55 pm Reply with quote
If your shower screen has been siliconed from the inside thats more than likely your problem . If so remove all the sealant from the inside of the screen ans seal ONLY on the outside , See if this does the trick.
Back to top
 Alert Moderators
LivvyB
from United Kingdom
PostPosted: Sat Mar 07, 2009 7:26 pm Reply with quote
Thanks for the tip...
Someone did tell me that maybe the bath was put in on a slight 'slant' downwards. Nothing you would notice, but enough so that the water ran behind the taps.
Does that make sense to you? Would re-sealing the outside as you suggest help do you think?
The next man I get will have to have the criteria of 'good at DIY' !
The floor is soaking and I cant use the shower so have to find a solution.
Regards
Liv
Back to top
 Alert Moderators
swidders
from United Kingdom
PostPosted: Sat Mar 07, 2009 7:57 pm Reply with quote
Have you actually identified where the water is coming from? Dry it all with a towel, turn it on and see where water is escaping.
Back to top
 Alert Moderators
LivvyB
from United Kingdom
PostPosted: Sat Mar 07, 2009 8:11 pm Reply with quote
I've just done that and its escaping from the bottom of the join where the fixing is and also under the flap' of plastic under the actual glass that sits on the bath..
Regards
Liv
Back to top
 Alert Moderators
swidders
from United Kingdom
PostPosted: Sat Mar 07, 2009 9:29 pm Reply with quote
Think the best thing would be to take it all off (wall bracket and all), dry it off completely and rehang it. I would say exactly vertical, but since the bath isn't level, so you describe, you need to hang it so it rests along the side rim of the bath.. Then run silicon along the outside of where the bracket meets the wall. Will be easier to do if you have a friend to help icon_wink.gif
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 502 times
PostPosted: Sat Mar 07, 2009 9:36 pm Reply with quote
What's the bath shaped like where the screen sits on it?
Some baths don't have a very good profile for a shower screen.
Back to top
 Alert Moderators
hampshireman
from United Kingdom
PostPosted: Sat Mar 07, 2009 10:12 pm Reply with quote
May I ask? Not quite the same problem, but why seal only on the outside? I have a fixed screen round a walk-in tray and will shortly be resealing 'cos the tray is moving.
Back to top
 Alert Moderators
swidders
from United Kingdom
PostPosted: Sat Mar 07, 2009 10:19 pm Reply with quote
If you seal both the inner and outer edges, then should any water get in (it shouldn't but has a habit of doing so anyway icon_confused.gif ) then it will not escape so easily and you have a damp area festering away with usual mold issues etc.
Back to top
 Alert Moderators
LeedsPlumber
from United Kingdom
Thanked: 20 times
PostPosted: Sun Mar 08, 2009 7:42 am Reply with quote
Remove the screen which will leave the profile that is screwed to the wall, you need to seal the inside of the profile (the bit that screws to the wall) at the bottom where it meets the bath with silicon all the way around, then put the screen in position it should stop the leak.
http://media.diynot.com/115000_114267_9393_66184550_thumb.jpg
Back to top
 Alert Moderators
hampshireman
from United Kingdom
PostPosted: Sun Mar 08, 2009 2:21 pm Reply with quote
Ok thanks. I like that foam idea.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaking hinge on shower screen 2 100 Mon Oct 13, 2014 12:30 pm
Leaking shower screen 3 120 Tue Mar 01, 2011 12:23 am
Leaking shower screen over bath 3 180 Fri Sep 20, 2013 3:20 pm
Leaking shower screen!! Help please 3 980 Mon Aug 10, 2009 8:35 am
leaking hinged shower screen 4 1020 Thu May 28, 2009 8:17 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
