Internal pine door vertical cut
14 Jun 2005
London
I want to install an interior solid pine door but rather than a standard install I want to cut it straight down the middle (vertically) french door style. I have a decent circular saw but am concerned that I may destroy the door if I do it.
Have looked around a couple of shops but can only find the bi-folding doors which I don't want. Does anyone know of a supplier or advice on cutting the door?
not a good idea at all
you will have a minimum of 5 seperate parts along the cut edge giving a weak edge
you will expose all the mortice and tennons in the centre off the door
what you can do is get a door 3" narrower than what you need edge with 2x2" planed [44x44mm] screwed and glued with the screws countersunk at least 13mm then trimmed to fit
this will still look odd particularly at the top and bottom but at least will replace most off the strength lost and hide the various joins
