DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hotpoint Frost-free fridge freezer broken
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
magicdust
from United Kingdom
PostPosted: Thu Mar 12, 2009 1:46 pm Reply with quote
Hi, this morning my Hotpoint fridge freezer (SFA47X) started beeping and the following message scrolled across the screen: 'Attention to the freezer food should be consumed immediately.' The bottom shelf of the freezer is defrosting and the food is now soft, the top two shelves seem to be okay. There is also ice at the bottom of the freezer.
I have rung Hotpoint and the next available engineer is next Wednesday! The guy I spoke to said it sounds like it needs a re gas, however another lady said I could try defrosting it. What does a re gas mean? Does it need an engineer to do it?
My appliance is out of warrantly so I can either extend it and get a call out or pay one off for an engineer - this thing has cost me so much already (both in terms of money and stress!) I'd like some advice and other peoples experiences with a similar problem. Any help would be very much appreciated icon_biggrin.gif
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1460 times
PostPosted: Thu Mar 12, 2009 2:10 pm Reply with quote
If it needs a regas, it has to be done by an engineer, and it will probably go wrong again with increasing frequency. My BiL who is a refrigeration engineer says he will not regas domestic fridges or freezers since they will never seal again as well as they did when they left the factory, and he gets complaints when it goes wrong again. If it does, then either get another service contract, or save up for a new machine.
Try this. You may have this very common problem with frost-free freezers (I did not know about it and spent a lot of money buying a new one)
Common Problem:
The ducts at the back, where the fans blow cold air and collect frost for later melting and draining, can get blocked with frost. they then stop working and you get the problem you describe. This can happen with age, or if the heating circuit is faulty, or if the door is left open allowing excessive frost build up
Cure:
Turn it off, and UNPLUG it, take all the food out and eat or store it or ask a neighbour to keep the expensive stuff. Open the doors. Pull it away from the wall so you can see the drain tray at the back that collects melt water
Leave it for AT LEAST 24 HOURS at room temperature to melt the ice in the internal ducts. Leave the door open so that water can run out or be mopped up. Look round the back and sponge the drain dish dry and clean. Look for any blockages of mould or food particles in the tube and poke with a soft thing like a pipe cleaner.
When you are SURE it has stopped dripping and there is no more frost or water in the ducts, plug it back in with a thermometer inside and monitor its temperature. If you have not allowed all the frost to melt you will have to go through it all again which is very tiresome.
If it does it again in a few weeks or months, and you are sure you have not been leaving the door open or putting uncovered wet things inside, call the engineer, as the heating circuit may have failed. It will be easier for him to work if you have started the defrosting before he arrives.
Back to top
 Alert Moderators
magicdust
from United Kingdom
PostPosted: Thu Mar 12, 2009 2:19 pm Reply with quote
Thanks a lot for your reply. I will try it tonight and start the defrosting process. Many thanks!
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 216 times
PostPosted: Thu Mar 12, 2009 4:48 pm Reply with quote
In reply to the comment on resealing.
I was in domestic appliance developement for many years, we would regas an appliance many times to determin the best volume of gas (this was the old R12). To seal was so easy, fill with gas, grip pipe, remove gas, soft solder over the copper.
Its easy as plumbing, because thats what it is.
Back to top
 Alert Moderators
teerak2uk
from United Kingdom
PostPosted: Mon Apr 25, 2011 7:48 pm Reply with quote
Hi Guys
old thread i know but i have a similar problem but i do ac on cars etc but how do you know how much to put into a fridge/freezer (Hotpoint FFA 60)
Many thanks
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1003 times
PostPosted: Mon Apr 25, 2011 8:02 pm Reply with quote
34 grams and the rating plate tells you r134 or r600 gas
Back to top
The following user says thank you to rocks1 for this useful post:
teerak2uk (26 Apr 2011)
 Alert Moderators
teerak2uk
from United Kingdom
PostPosted: Tue Apr 26, 2011 7:42 pm Reply with quote
Thanks for that matey also do they have normal filler ports (quick release coupler type)
Also is it possible to replace door seals on these when they need doing
Back to top
 Alert Moderators
rocks1
Thanked: 1003 times
PostPosted: Tue Apr 26, 2011 7:49 pm Reply with quote
No u have to use lockrings once its been cut on the pipework, then you have to vac it out and poss change the dryer that's next to compressor.
Back to top
 Alert Moderators
teerak2uk
from United Kingdom
PostPosted: Tue Apr 26, 2011 11:12 pm Reply with quote
ok thanks matey but any ideas where to get the lockrings from
Back to top
 Alert Moderators
docgibbons
from United Kingdom
PostPosted: Tue Jun 21, 2011 9:00 am Reply with quote
i have the same problem, although the temperature is clearly ok. the fridge part keeps everything chilled, and the freezer part freezes. still keeps peeping though.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1460 times
PostPosted: Tue Jun 21, 2011 10:01 am Reply with quote
docgibbons, read what I said Thu Mar 12, 2009 3:10 pm and try it.
Back to top
 Alert Moderators
docgibbons
from United Kingdom
PostPosted: Tue Jun 21, 2011 10:07 am Reply with quote
thanks, am trying it today. although my problem differs slightly in that the food is not defrosting, and temperatures appear ok. i can't check the exact temperatures though as the digital display is not working either.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint FFA90 frost free fridge freezer 2 1160 Sun Mar 27, 2005 6:23 pm
Hotpoint Frost Free Fridge Freezer Model no FF200E 3 20 Thu Sep 15, 2011 1:28 pm
Hotpoint Frost Free Fridge & Freezer Warm - Timer Maybe 2 100 Wed Feb 16, 2011 9:01 pm
Beko CDA 539 FS Frost Free Fridge/Freezer Problem 3 4000 Tue Jan 18, 2011 10:36 am
Samsung Fridge/Freezer (Frost free) - Ice forms at bottom 2 2420 Sat Nov 04, 2006 11:04 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
