Fernox Leak Sealer
9 Mar 2009
Cleveland
Hi again everyone.
Quick question for you... I put some Fernox leak sealer into a open vented system yesterday as there was a pinhole in a radiator pipe, the pipe couldn't be replaced as it was laminate floor with concrete underneath.
The fernox seemed to fix the problem luckily - I was just wondering, if the system is ever drained in the future, will i have to add the leak sealer again, or once it's worked is that it??
Any help would be apreciated.
David.
I would ask the manufacturer on this one but I personally would look at replacing the rad as one pin hole of rust will mean another.
You are only buying time with leak sealer IMHO. :cry:
Thanks for the reply.
It's not the rad that has a pinhole in, it's the pipe - there's a kink where it comes out of the concrete floor and that's where it was leaking from.
To replace the pipe, i would have to lift the laminate floor, then chisel away at the concrete. Otherwise, i would have replaced the pipe straight away.
David.
