Hi there,
We have had plumbing problems of various sorts for a few years.
We have had various people in, and more recently I've had by brother in who is Corgi registered and quite a well regarded plumber locally, but none of them seem to be able to fix things.
Boiler is an Ideal Icos HE15
Anyway, here is what is happening, I think there may be 2 faults, no idea if they are related- they don't seem to be.
First Fault
Firstly, with just the heating on, everything runs pretty well for 20-40 mins. Then the boiler switches off showing an LF code. Resetting it then causes LF again and again. Sometimes if you switch the system off for a while it will light again.
My brother cleaned the condense trap and pipe but it didn't fix the fault. I believe his next move is the gas valve when he gets time. Is there anything else he should be looking at before this or while doing the job?
Second fault
The second fault (which as I say may or may not be related to the first) occurs when the hot water is on.
With just the HW on, the boiler lights, heats water for maybe 20-30 seconds, then there is banging noises from the boiler and it shuts down. When I say shuts down, I mean that it stays on, the "C" remains on the display which I think indicates it is still getting a call from the heating, but the light starts flashing (it's solid when lit).
Additionally, if I listen to the pump when the HW is on, it sounds a little louder, as if under strain. Also, there is a bleed valve near the pump and cylinder (pipe from pump goes up into the electric valve, the valve is at the top of the pipe that comes out of the valve on the HW side, a few inches above where it enters the cylinder.) Anyway, I can keep bleeding air off here all day, it just keep filling. Sometimes, I bleed the air off and water comes out, sometimes the air just runs out (water head too low??)
With the heating and water on, the rads fill up with air while the boiler is running. That is, I can walk around bleeding the rads, by the time I have done the last one, the first one needs bleeding again.
THIS ONLY HAPPENS WHEN THE HOT WATER IS ON. Rads stay 100% full when just the heating is running.
Anyone any ideas? I'm at the end of my rag, my brother can only get down every week or so, he does things which seem to fix the problem but then a few hours after he has gone they will start again.
Cheers,
Dave
First Fault
Second fault
Cheers,
Dave
