Petrol Hedge Trimmer
21 Mar 2009
Isle of Wight
I have a petrol hedge trimmer and the instructions state that I have to prime the carburrettor by pushing the primer bulb 10 times but not fuel seems to flow - we have had the hedge trimmer for a while but never used it - any advice
Model Performance Power PWR24cchta
10 times seems like far too many. Check the fuel line at the carburettor end to see if there is fuel flowing to it. Next check the plug to see if it is sparking and if is wet after repeated starting attempts i.e. more than 5 or 6. If its sparking ok you'll need to check the carb properly but If you are not sure how to do this try and enlist a friend who does
Mine is 10 times too, so that'll be right enough. Pump it until the bulb is full of fuel even if that means 100 times.
Excess priming only returns fuel back to the tank.....check that the fuel pick up pipe is actually within the fuel ( a common occurrence is that it can float free). If the bulb won't fill, the carburettor has a sticking diaphragm 'flap valve' which will need investigating.
