bathstore toilet and cistern problem...
22 Mar 2009
Yorkshire
Recently purchased 3 toilets from Bathstore...all have Geberit internals pre installed...have fitted first one no probs, second one in bathroom, all connected up cistern fills with water, feed valve shuts off OK, but I have water running into pan constantly ! Not down the internal overflow pipe either...its like the rubber seal ring on flush valve is letting water pass somehow ? Have taken the unit from new (yet to be installed) 3rd cistern and tried that with the same result :?:
Any thoughts or ideas please....thanks
Maybe the washer were the syphon has been screwed to the bottom of the cistern hasn't created a good enough seal.
Take the cistern off, from underneath make sure the washer is covering the full diameter of the hole and the nut is tight enough.
yes good point...I had considered that to be honest...the other thing I was gonna try was to replace the whole cistern with the 3rd one, which is destined for the en-suite if ya know what I mean...
All the internals are pre - installed, but I did check them all for tightness etc...seemed OK. But summat is clearly not right somewhere...will keep ya posted...thanks for response tho ;)
Hi
Certain older Geberit flush valves could be detached from the base nut without the need to dismantle. They had tabs either side low down. Check if this is still so before taking completely to bits.
Check the 3rd one over the bath prior to install.
HTH
take them back or get them to fix them on site :idea:
