Block paving - bedding (construction method)
vw
2 May 2007
Yorkshire
I am going to DIY for block paving. I have done the calculation, layout and foundation investigation etc. Can you please advice me on construction method follows:
The area of block paving is about 24 sqm. If I am not able to complete the project within a day, I want to break the works into two stages.
The first day: edging block and bedding (30mm thk)
The second day: complete the rest of works
My question is:
After the first stage, can I leave the sand overnight (I try to pick the dry days during the construction), then start laying the paving block on the following day.
Many thanks in advance
You will not be able to set edges in concrete and then run a vibrating plate up to or against them. Its easier to do all your edges and leave them to harden for a day. As for screeding sand and leaving it overnight no problem, but anything heavier than a brief light shower will wreck it. also you will be amazed at the footprints you will find in it the next day.
To be honest it is usually easier to work in sections anyway, assuming there are no complex sweeping sections that are not level and need to meet eachother, there is no problem with laying and plating half of the area with sand it and then starting back in on it the next day, But don't lay right to the edge of your screeded sand as you need at least a metre or so to continue your level
