WasherDryer wjs1397w zanussi 1250 jetstream - stopped cycle
29 Mar 2009
London
The cycle hangs after it has filled the drum. When it hangs a noise/motor from the the recirculation pump is running. Drum goes round on some cycles, like when its draining or filling.
- I took the recirculation pump apart and the paddles/impellor that push the water round seem to be missing!, they might of broken off not sure. should the recirc. pump have paddles like the main pump? How do i check the pump motor is ok?
- I have checked the brushes and they are a worn but ok
- Have blown down water intakes - seam ok but not click sounds
- Have cleaned out main pump and hoses (full of gunk, kids toys and a 5p that somehow got in-between the two pumps). How to check hoses are un blocked? stuck clothes hanger wire down them.
- I suppose it might be a duff heater element and thats why its hanging i.e. its needs to heat up water at that point. How do i check this?
This is a 8 year old machine, its was really full of gunk its - the 3rd time its broken in 3 years bah.. don want to buy a new one yet..
ta+
the drain pump and recirculation pumps should both have vanes on the impellors
typical was cycle is
fill
rinse
drain
fill
heat
main wash
drain
rinse
drain
spin
if it cant drain it will hang and can burn out pump
to check the pump you can connect 220/240 Volt AC to it while off the appliance (it needs impellor vanes/blades though)
or
switch to drain or spin program only, pump should operate and drain
Do you use liquid detergent and no hot washes (60 degree C or above) as this can gunge up the inners of the machine
thanks for the info
working now.. yes we use liquid soap(and it bunged up after using vanish stain/whites remover powder). Cleaning out the pumps and tubes and putting it on a hot wash with dryer has sorted it out..
is there a tool for sticking down the pipes to unblock them?
although i've now learnt that the recirculation pump (i.e. jetstream feature) is not working and i need some new brushes asap...
ta
rafal
