DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flashing red light on my boiler?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Craiguk44
from United Kingdom
PostPosted: Wed Apr 01, 2009 12:14 pm Reply with quote
I have a Sime Format C and the red light on the rad settings is flashing?
I cant get any hot water!!??
Back to top
 Alert Moderators
Gas2Air
from United Kingdom
Thanked: 96 times
PostPosted: Wed Apr 01, 2009 12:32 pm Reply with quote
And your pressure guage bottom left is showing what?
Back to top
 Alert Moderators
Craiguk44
from United Kingdom
PostPosted: Wed Apr 01, 2009 12:37 pm Reply with quote
Iv put just short of 2 bar into it.
Back to top
 Alert Moderators
Craiguk44
from United Kingdom
PostPosted: Wed Apr 01, 2009 12:43 pm Reply with quote
I have the heating on constant, but it kicks up for probs 30seconds then shuts down again, 2 minutes later the same thing happens, even tho the rads are freezing!
Back to top
 Alert Moderators
Gas2Air
from United Kingdom
Thanked: 96 times
PostPosted: Wed Apr 01, 2009 1:08 pm Reply with quote
Ignition/sense fault. Usually ignition PCB on this marvel of a boiler. Get someone to have a look and rectify.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Wed Apr 01, 2009 1:12 pm Reply with quote
Is it a combi and is the DHW working normally or not?
That time scale makes me wonder if its a CH sensor failing when it gets warm.
With the boiler cold measure the resistance with the lead off.
Tony
Back to top
 Alert Moderators
Gas2Air
from United Kingdom
Thanked: 96 times
PostPosted: Wed Apr 01, 2009 1:18 pm Reply with quote
I will stick my neck out here and say it was a Friendly Format 80 c Tony. A combi. CH sensor fault will make LED go orange.
Back to top
 Alert Moderators
Craiguk44
from United Kingdom
PostPosted: Wed Apr 01, 2009 1:27 pm Reply with quote
Thans for that, iv had a bit of training in plubing so once you mentioned that i opened the control until up and the yellow and green wire in the ignition unit was shorting. Thanks very much!! icon_biggrin.gif
Back to top
 Alert Moderators
Gas2Air
from United Kingdom
Thanked: 96 times
PostPosted: Wed Apr 01, 2009 1:37 pm Reply with quote
Back to top
 Alert Moderators
Craiguk44
from United Kingdom
PostPosted: Wed Apr 01, 2009 2:06 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera boiler green flashing light after water pressure fix 2 60 Sun Feb 16, 2014 6:55 pm
BOILER INCREASED PRESSURE HOT WATER LIGHT FLASHING BUT NO HE 4 40 Fri Sep 23, 2011 2:25 pm
vokera linear 24 boiler, wont reset, flashing red light! 01 5 80 Sat May 05, 2012 6:33 pm
Turbomax Plus 824E Combination Boiler -green flashing light 4 120 Wed Mar 23, 2011 2:04 pm
Worcester combi boiler 28cdi red light flashing 31 1740 Sun Dec 29, 2013 2:01 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
