DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton Suprima 30- problems locking out constantly
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Antigua
from United Kingdom
PostPosted: Thu Apr 02, 2009 6:01 pm Reply with quote
Hi. I've just had a new PCB fitted and now when the demand is on for either the hot water or heating (or both) the boiler will fire up and get warm, it usually takes about 30 minutes, and then it will cut out- the green light will flash constantly-before the red light comes on, the boiler will temporarily knock off, and then reignite if the demand is on. The boiler will then work for approx 4 minutes, before the green light starts to flash again, then the red light will come on, then it will reignite and come on again for 4 minutes and so on.
I have also noticed that I can hear fast flowing water in/around the boiler and before all the problems with the PCB I never heard water before, or had the cut out problem.
I've had a BG engineer out to investigate who says there's nothing wrong and its normal to go on and off so frequently, but I'm not convinced? icon_sad.gif
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Thu Apr 02, 2009 6:07 pm Reply with quote
as usual BG is talking bllx
you have a problem.
get them back
Back to top
 Alert Moderators
Antigua
from United Kingdom
PostPosted: Thu Apr 02, 2009 6:38 pm Reply with quote
you have a problem.
get them back
Any ideas on what it could be? It's driving me insane!
Back to top
 Alert Moderators
BingoBongo
from United Kingdom
Thanked: 96 times
PostPosted: Thu Apr 02, 2009 9:34 pm Reply with quote
flashing orange and green is air proving and ignition
the new pcb differs from the old 1.1 led insted of 2
the boiler will lockout now whenever the temp of the overheat stat is reached.
the requirements for a bypass must be met
3port valve "y plan" no bypass req
2 2ports "s plan" 4 m of 22mm pipe
Full trv system - 2m of 22mm pipe
thermistor fault-red every 5 secs
wiring harness-red/orange 3 times a sec
false flame-red orange every 5 sec
aps-red 3 times a sec
pcb-solid red
ignition/lockout-flashing red every second
(My lucky numbers 54, 146, 171, 44)
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3598 times
PostPosted: Thu Apr 02, 2009 11:14 pm Reply with quote
But, just like British Gas, dont expect the PCB to get it right every time!
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2772 times
PostPosted: Fri Apr 03, 2009 2:54 pm Reply with quote
Antigua wrote:
......I've had a BG engineer out to investigate who says there's nothing wrong and its normal to go on and off so frequently, but I'm not convinced? icon_sad.gif
Has it always done this? If not, then it is clearly not normal.
If it is a real lock-out as opposed to temperature satisfaction, that in itself is also proof it is not normal as a lock-out is safety system that engages when conditions go beyond normal.
As advised above: get them back and keep getting them back until the system performs correctly. You paid to get your boiler fully fixed, not for someone to run some experiments.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
potterton suprima 100 locking out 3 700 Thu Oct 20, 2005 7:18 pm
Problem with my Potterton Suprima 50 Boiler and locking out? 14 1040 Mon Aug 21, 2006 9:05 pm
Potterton Suprima 70L Boiler Locking Up 2 2260 Thu Aug 09, 2007 8:28 pm
Potterton Suprima 40 - Locking out 8 480 Mon Nov 03, 2008 5:53 pm
potterton suprima 80L. locking out and water gauge dropping. 2 260 Sun Dec 20, 2009 11:25 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
