Wochester Bosch 37cdi 2007
4 Apr 2009
Hi
I had a Wochster Bosch 37 CDI installed in 2007, when it was fitted the plumber wired it to the old external thermostat i think he removed a link from the control panel at the time, i have now disconected and fitted a DT10RF thermostat and the boiler wont switch on could anyone help.
Rgeards
JB
Dont put the link in, is the attanae symbol in the display flashing ? If it is then all you have to do is set up the link between receiver and transmitter. Instructions are, as already advised on the worcester website.
I'll type this slowly so you can understand.........
The DT10RF is WIRELESS, therfor you wont get a wiring diagram ;)
Replace the link between Ls and Lr on the terminal block marked ST10.
With the reciever plugged into front of boiler and batteries in stat/sender unit, follow the destructions.
:rolleyes: ;)
