DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton Suprima 50
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
whattodo
from United Kingdom
PostPosted: Sun Apr 05, 2009 4:16 pm Reply with quote
I have a Suprima 50 and 3 years ago I replaced the pcb with part no 5111603. Last night I noticed that the system pump was running however the programmed time was off. I checked the boiler and found a constant red light. According to the info that came with the replacement pcb this is a "system wiring fault" the cause of which is "either pump live is not wired directly from the boiler to the pump" or, "live and neutral are reversed"
As the pump is running and no work has been done to intefere with any of the wiring does this mean that this "updated" pcb is faulty as well !!!!!!!!!!!!!
Can anyone help please
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 818 times
PostPosted: Sun Apr 05, 2009 5:11 pm Reply with quote
Have you tried turning off at the wall for 30 seconds then seeing what happens?
Back to top
 Alert Moderators
EddieM
from United Kingdom
Thanked: 60 times
Has it got a reset button, if so press it!
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 243 times
PostPosted: Sun Apr 05, 2009 5:55 pm Reply with quote
first thing to check is the live and neutral are in fact the right way round. a few times i have had people swear blind there is no issue with reversed polarity only to find that it was at fault.
is the pump wired directly to the boiler?
Back to top
 Alert Moderators
whattodo
from United Kingdom
PostPosted: Sun Apr 05, 2009 6:18 pm Reply with quote
thanks for the replies, I have turned off the power supply and switched it back on. As soon as the power is restored the solid red light appears and the pump starts running. I have tried the reset button but the light shows orange for only one second or so and then turns red. None of the wiring has been touched since the pcb was installed so I just cant see how that can be the cause. Any other ideas?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 818 times
PostPosted: Sun Apr 05, 2009 9:22 pm Reply with quote
Unfortunately any make and model of boiler can get a faulty pcb again and again.
When it is a boiler with a bad reputation one tends to jump to conclusions very quickly.
It sounds as if it does need replacing, but we are not there to ascertain this for sure icon_wink.gif
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 243 times
PostPosted: Sun Apr 05, 2009 10:24 pm Reply with quote
whattodo wrote:
. Any other ideas?
how about actually acting on the ideas already given to which you have given no reply. icon_rolleyes.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3616 times
PostPosted: Sun Apr 05, 2009 11:44 pm Reply with quote
Nickso means measuring the polarity of the supply to the boiler.
Or getting someone to do it for you!
At about 250 each its an expensive part to change if its not failed!
I was once called to a boiler that had gone wrong! It transpired that the girls father had rewired her flat because the polarity was wrong.
The boiler installer had noticed that and connected it appropriately to work in that senario but without marking the outside of the boiler.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Centreal Heating not working on my Potterton Suprima 3 40 Wed Oct 10, 2012 10:13 am
potterton suprima 40 boiler 3 280 Mon Apr 14, 2008 6:20 pm
Potterton Suprima switching on and off for no reason? 2 1180 Sun Mar 05, 2006 11:32 pm
Potterton Suprima 70L Broken 4 480 Sat Mar 04, 2006 12:02 am
Potterton suprima 40 6 80 Fri Oct 12, 2012 4:56 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
