Guys,
I've recently noticed that my Vokera Excell has had delay in firing when turning on a hot water tap (about 15 seconds), after reading similar posts on here I reckon that the divertor valve needs refurbishing. In past posts you mention a service kit for the valve, do any of you have the part number for this ket so I can order one???
Additionally I have also noticed that if the hot water is not used for a period of over 15 minutes when I turn a tap on I here a noise from the boiler almost like it is filling up, or there is a restriction of flow. This occurs for about 3 seconds before remedying itself. It is also accompanied by a reduced flow from the hot water tap, again this remedies itself after 3 seconds or so.
If it helps I recently replaced both the flow and domestic HW diapragm when I initially noticed the problem with the delay in the boiler firing.
Any advice would be appreciated,
Mark
Mark
